Tires with built in camber: thoughts?
Old Sep 11, 2010 | 07:54 AM
vjarnot's Avatar
Default Tires with built in camber: thoughts?
http://www.cambertire.com
Yeah, their website is trash.
Saw this mentioned in the current Autoweek. I can't decide out if this is a passing fad with no performance advantage, or something that we'll all be running in 3-5 years...
Thoughts?
Old Sep 11, 2010 | 08:38 AM
PedalFaster's Avatar
Look like the triumph of marketing over science to me:
  • Automobile Magazine tested them and declared them to be superior. How exactly they came to this conclusion is completely beyond me given the data. The performance of the 140 treadwear Scott's tire was essentially identical to the performance of the 180 treadwear identical tire. The R-compound Scott's tire running 3 degrees of negative camber outperformed the 180 treadwear street running 1 degree of negative camber, but that proves nothing -- a conventional R-compound tire running 3 degrees of negative camber would also outperform a 180 treadwear street running 1 degree of negative camber.
  • Many people have argued "racers have been doing this forever, so it must work", not realizing that racers have actually been doing the exact *opposite*. The fabled BFGoodrich Comp T/A R1 tires had stiffer (and thus effectively dynamically taller) inside sidewalls, whereas the Scott's tires have taller outside sidewalls. Likewise, those who shave their tires asymmetrically shave more off of the outside edge to make it shorter (and build in more effective camber), whereas the Scott's tires have a taller outer edge (building in less effective camber).
Complete and utter snake oil, in my opinion.
Old Sep 11, 2010 | 09:27 AM
Froth.'s Avatar
A cone doesn't roll straight. The tire will want to fight itself going down the road. As said above, this seems like a Snake-Oil marketing gimmick.
-Froth
Old Sep 11, 2010 | 11:03 AM
Sinji's Avatar
-Froth
definately snake oil!
theS2K
Jul 12, 2015 11:05 PM
Accel Junky
Apr 11, 2013 08:17 PM
BakktoJDM
Jan 24, 2011 12:16 PM
slipper
Aug 25, 2007 05:57 AM
blue2k2s2k
Mar 22, 2005 06:23 AM
