Tires for my new wheels
Old Sep 8, 2007 | 09:10 AM
EVIL-S's Avatar
Default Tires for my new wheels
I have some Volk Re30s comming in in the next few weeks and i need to start planning for tires.
Here are the specs.
Fronts 17X7.5 Offset 43
Rears 17X9 Offset 63
Now with a few questions. can i run a 45 series tire on the rear like the front? I am running Tein MonoFlexes
And what is the widest i can run without rubbing. (245,255, 265)
Thank you for your help.
Old Sep 8, 2007 | 09:21 AM
SpeedxRacer's Avatar
you can go wide with those offsets... 265 will probably fit easy in the rear.. And oh run 40 series in the rear.
Old Sep 8, 2007 | 09:24 AM
EVIL-S's Avatar
I am looking for a "beefy" look for the rear. I was thinking 265 but then thought i would rub.
Old Sep 8, 2007 | 09:29 AM
EVIL-S's Avatar
Also if i was to run a 265 rear which tire should i run for good grip and good daily driving. Tire Rack dosent seem to offer much in that size.
Old Sep 8, 2007 | 10:17 AM
Jim@tirerack's Avatar
Former Sponsor
There isn't much made in the 265/40R17 size. The real problem would be the front tires with the 17X7.5 wheel and a 43mm offset. I would not go wider that a 215/45R17 in the front. You are going to have more choices if you go with the 215/45R17 front and the 255/40R17 rear.
If I can help let me know.
Old Sep 9, 2007 | 09:23 AM
EVIL-S's Avatar
IS there a reason i need to run 40 series in the rear? Is 45 series in the rear a no no?
Just asking.
Old Sep 9, 2007 | 09:50 AM
Project22a's Avatar
45 will make it taller than the OEM overall diameter, it will throw off your speedometer and it increase your chances of rubbing.
Old Sep 9, 2007 | 09:51 AM
EVIL-S's Avatar
gotcha, just wanted to know
Thanks
Old Sep 12, 2007 | 01:10 PM
EVIL-S's Avatar
Ok if i was to run 215/45R17 front and the 255/40R17 rear whcat tirs do you guys recomend? I have been looking but it is hard to find the fronts to match the rear.
Old Sep 14, 2007 | 01:13 PM
Ape_X's Avatar
What type of conditions will the car see? Just street? Street/track? Do you want all out max dry grip with no concern for wet traction? All season? Snow?
