TIRES + WHEEL SIZE
Old May 22, 2014 | 08:55 AM
biondoS2000's Avatar
Default TIRES + WHEEL SIZE
PLANNING TO BUY ENKEI RPF1 SHORTLY....
WAS THINKING 7.5+48F MAYBE 8 DEPENDS ON IF i STAY WITH 215 40 INSTEAD 45 / 9+45R
WHAY DO U GUYS THINK ABOUT 215 40 17 FRONT & 245 35 17 REAR?
WOULD THE SIDEWALL MATCH CONSIDERING THE DIAMETER OF THE TIRES? OR MAYBE SHOULD i KEEP 4O IN THE REAR
I DON 'T WANT TO TOUCH THE FENDER IN ANY WAY, JUST WANT TO PLAY WITH CAMBER IF NECESSARY.
Old May 22, 2014 | 09:15 AM
Manga_Spawn's Avatar
Site Moderator
First turn caps lock off. Second with those wheel you will need to roll the fenders. If you are doing either 7.5 or 8 width in the front a 225/45/17 is good. 215 is fine as well though if you do an 8 I would definately do the 225. For the rear if you are running a 9 inch wide wheel you should run a 255/40/17. You can run a 245/40/17 if you want a bit more clearance but it won't mean you don't need to roll the fenders.
blueprint
Sep 21, 2015 11:10 AM
kulo
May 18, 2012 08:56 AM
S-ZGk
Dec 17, 2010 01:14 PM
Trent06
Oct 27, 2010 02:03 PM
f23power
Oct 27, 2009 09:16 PM
