Toyo R888 problem
Old Mar 2, 2009 | 06:17 PM
s2kwhitepanama's Avatar
Default Toyo R888 problem
Hi everybody , i want some advices ... welll my type of driving in 1 - 10 is like 6 i like to run and take some turns but i never launch from 0 or 1 gear and i dont do drift , donuts , all that crap that damage your car , my type of driving is enthusiasm and spirit , winding road , touge , highway , daily drive etcc . well right know i am running ventus k105 hankook tires that cost me 500 $ but previously i ran r888 toyo and they cost me like 400 $ but they last only like 4 months but the front r888 are ok i think they didnt last to much because i change my tein height and i lost aligment setup ...with the ventus the car just sucks doesnt handle like the r888 the braking is less and i hate the grrrrr sound when you take a turn because scare me .... the thing is that i dont put so many miles to the car but is my daily drive and this ventus tires have only 4 months and the rear just look like for 2 months more the thing is i want to put r888 again only buy the rear the thing is that , if a used the front used r888 and the rear ones new this would affect me in something or not.... i want to know also some advices to take more car of the new r888 toyo tires so they can be used for more than 4 or 5 months and when the rear ones are ended i just changed the rear .... thanks for the advices and comments and i also do my search bottom but i did not found to much info... sorry for my strange english but is my secong language ... los que entienden espa
Old Mar 2, 2009 | 06:24 PM
mikegarrison's Avatar
Perhaps it is because English is your second language, but did you not see the large letters on the side of the R888 that say "FOR COMPETITION USE ONLY"? Of course a track tire is not going to last very long when used on the street. That's not what it is designed for.
Honda Life Dunk's Avatar
You want to know if you can put new tires on the rear with older tires on the front?
Yes you can. Just make sure all the tires have enough tread.
Old Mar 2, 2009 | 06:29 PM
HotDamnitsDavid's Avatar
Exactly!
Old Mar 3, 2009 | 04:46 AM
Triple-H's Avatar
And that they are all the same compound, as in R888 at all 4 corners and nor R888 at one end and k105 at the other end.
Old Mar 3, 2009 | 04:49 AM
Triple-H's Avatar
The reason they did not last is because they are not a street compound tire, they are a competition tire which means the rubber compound is very soft.
Soft rubber equals a lot of grip and, low mileage ratings.
You can't get grip like an R888 offers and expect to get a lot of miles out of them.
Old Mar 3, 2009 | 06:32 AM
but my ventus only last 6 monthsr888 4 mmonths 400 $ for track performance on streets.... good
Old Mar 3, 2009 | 07:26 AM
//steve\\'s Avatar
Like a couple others have said above, you are running the wrong tires for a car that doesn't get driven on the track. Look into something like the dunlop z1 star specs or bridgestone re01r. They might cost you a little more but should last longer and will provide more than enough grip for a street car even if you are going out to have fun from time to time.
Old Mar 3, 2009 | 10:00 AM
T111MYO's Avatar
Im running Toyo Proxie T1r tyres on my car and they are excellent on-road grip and also proven better than R888 in wet weather.
Mine have lasted a long time already, seems like they will last me a fair amount of time without even thinking of changing them soon.
Remember keeping ontop of tyre pressures are vital so your tires last longer but as a few have said already, the R888 is a soft compound tyre for track use so it isnt going to last long if used on road.
Old Mar 3, 2009 | 08:26 PM
bzerkkiller's Avatar
maybe you're running too much negative camber.
less negative camber will result in longer tire life but less handling capacity/ability
