volks le37 help on scratches
i have set of le37 with couple of big scratches on the lip and the spokes. y drove home drunk one night will never happen again. can i powder coat a differ color but how do i get the scratch off the lip and also how much does it usually range from.
My buddy slid around a corner a while back and smacked both of the driver's side wheels on the curb. He used an electric sander with a high grit paper and then re-sprayed them with rustolium and you can't even tell he ever hit them at all.
If you can't do them yourself a bodyshop shouldn't charge much more that $25 per wheel then find a good powder coater and you're good to go.
From what Im told from wheel repair shops, JDM wheels have a different finish on the lips that can not be replicated in the states. If you fix one it will look different from the other 3 unless you do them all. Yes you can powder coat them. I got a qoute about 350 to prep and refinish my wheels in black.
SpeedxRacer
Oct 6, 2004 01:37 PM
new wheel is the one way out? thx again
