volks and tire size
Old Aug 22, 2013 | 06:16 PM
Suzuka_BlueS2K's Avatar
Default volks and tire size
What tires sizes are reccomended for 18x7.5 43 18x9.5 40? I'm really low about 2.5-3 inches and want to know if I'm risky out back.
Was thinking 215 /40 255/35 but the 40 offset has me worried and I don't want a lot of stretch. I'm rolled front and rear.
Currently I'm on 17x9/10 bbs lm 42 and 50 offsett. How much risk is the 40 out back? Will I rub and have to raise?
Current height and setup
Old Aug 22, 2013 | 06:18 PM
Would like to close wheel gap some will the 18 do that or is lowering needed?
Old Aug 22, 2013 | 06:22 PM
1nate7's Avatar
What wheel gap? Overall diameter will stay the same provided you pick correct sidewall height, you will just have more wheel and less tire. If you are worried about rubbing, start with a 245/35 rear. Difference compared to your current setup is minimal, any rubbing should be able to be corrected with a little more negative camber or slight fender pull.
Old Aug 22, 2013 | 06:51 PM
Thanks for reaponse. I have about a .50 inch gap out back. I'm currently -2.3 camber out back I suppose I could bump it to -3. Def do not want to pull the quarters.
Old Aug 22, 2013 | 06:52 PM
Also I saw 245/35 on the nt03 too much stretch for me.
Old Aug 26, 2013 | 04:50 PM
Looks like ill have to run 245/35/18 in the rear at rhe height I want to avoid issues.
What should I run up feont? 215/40 to keep in line with the rear 245? Its a 7.5 43 up front.
Old Aug 26, 2013 | 08:47 PM
s2000Junky's Avatar
No. If you run -3 out back you can run a 255.
The front you could go either way. I probably would just go with a 225, simply because on a 18" there is less sidewall and this adds a little stretch and clearance over the 17 counterpart.
Old Aug 26, 2013 | 11:30 PM
Thanks man I ordered 225/255 will report back on what happens later this week I hope
Old Aug 27, 2013 | 08:42 AM
jst2878's Avatar
Keep the 17s on
Old Sep 7, 2013 | 01:30 AM
As promised a couple pics. Went with 255 and 225. Camber is front -2.2 rear -3.2. Rear still rubs on hard bumps. I'm rolled and trim and relocate tab. Any suggestions? I've trimmed a lot but still rubs where bumper meets quarter. Help!!!
ktpp35
Mar 1, 2013 07:31 PM
RedSunS2K
Jun 9, 2010 06:47 AM
elcoqui1
Mar 18, 2010 02:47 PM
Shvitz2k
Apr 19, 2004 01:17 PM
ccajun4real
Jul 26, 2002 06:54 AM
