What is involved with getting the 2002+ NSX wheels
Old May 20, 2006 | 06:41 AM
Jo2's Avatar
Jo2
Default What is involved with getting the 2002+ NSX wheels
17x7 front, 17x9 rear wheels. The set i'm looking at has Falken 215/40ZR17, & Sumitomo 255/40ZR17 rear.
Some additional info i've found on nsx prime:
Offset (2002+): 55 mm front, 56 mm rear
Center bore (all years): 70(.1) mm front, 64(.1) mm rear
Lug nuts (all years) 19 mm with 12 mm x 1.50 thread pitch
so my questions are.....what will I need? Different lug nuts? Hubcentric rings? or should these bolt right up. Per the wheel guide sticky, i'm thinking the tires on the wheels will also work. Are they the best choice size wise with those offsets?
Any input would be great!
I'm trying to pull the trigger this week between either these or some volks.
Old May 20, 2006 | 07:44 AM
[AP2-2NV]'s Avatar
the front will sit just like the oem one. the back however will be pushed out about 15mm from where your oem ones are. with the factory alignment this will put the edge of the rim about 2 mm inside the fender. the only problem you may have is that with a 255 depending on your drop, you may need to roll the fender a little not to rub.
Old May 20, 2006 | 01:59 PM
rijowysock's Avatar
whor u getting them from?
i have modded fenders so theyd fit me perfect..
pm or email me PLLLLLEEEASSEE
Old Jun 19, 2006 | 02:04 PM
Jo2's Avatar
Jo2
Does anyone know if i'll need hubcentric rings??
Old Jun 19, 2006 | 06:54 PM
[AP2-2NV]'s Avatar
dont think so. hub specs are the same size.
FFP*Ron
South Florida
Jan 4, 2011 06:12 PM
llxzxll
Dec 15, 2008 05:19 PM
X4DLuvOfSpeedX
Feb 16, 2007 10:20 AM
Mr. Bean
Sep 24, 2006 09:47 AM
gchien
Dec 21, 2005 03:58 PM
