What Rims for S2000? Size, offset etc
Hi Guys
Im looking to get a set of Rims for my S2000 (havent picked it up yet!!). I want either 17 or 18". I would like to source some used ones.
What size should I look for?
And tyre size?
What should I consider in regards to offset?
If I find a set with a different offset is there something I can do to get them to fit?
Anything else I need to look out for?
Thanks
Mark
And tyre size?
Thanks
Mark
i PiCKED UP A SET OF 18@ WORK WHEELS. 18X7.5(FRONT) & 18X9(REAR). i WENT WiTH 225/40/18 iN THE FRONT AND 255/35/18 iN THE REAR. THE OFFSET iN THE FRONT iS 52 AND THE REAR iS 58. HOPE THAT WiLL HELP YOU OUT.
Originally Posted by Mugenboyz,Aug 19 2004, 07:08 PM
[B]For 18"s rims. Front 8" wide and Rear 9" wide. Offset should be 55mm and 60mm. Will look perfect when u drop it 1".
Ryan
