What size wheels and tires are recommended?
I pick up my s2 on Sat. and the first thing I'd like to do would be to replace the stcok rims. It's a 2000 model, my preference for wheel size is the bigger the better aesthetically, but I definitely don't want any rubbing and I don't want the handling to suffer. I figure it'll end up on the track before long. Can you all assist in recommending the appropriate sizes?
Thanks - I'm sure I'll have more questions.
I know there's tons of different combinations. That's why this gets a little confusing. I would like a larger wheel, preferrably an 18. as for the offset, i'd like something to extend far enough out to where it's close to being flush w/ the fender. as for tire size, I'm not sure, low enough of a profile so as not to rub. and wide enough to get good grip w/o being excessive. i would also like something that's an all season tire. I don't know if that's enough information for you to spec me out the exact size for a tire and wheel combination or not. i hope so. then i can look and see what's available for the car. that's the other thing - if i serach by car, i only get maybe 10-15 options. i like the SSR GT7's and some of the black Rota wheels but didn't see them when searching by car. would i just tell you the wheels I like and you could see if they were available in the size needed and then give me a price?
if you can help, i'd greatly appreciate it.
thanks again
thanks again
thanks again
thanks again
