What tyre size to run....
Old Oct 29, 2009 | 04:50 AM
jonner's Avatar
Default What tyre size to run....
17x8 +47 front
17x9 +44 rear
Is anybody running these sizes and offsets.....???
Could they post a pic too please.....
Old Oct 29, 2009 | 01:49 PM
Jim@tirerack's Avatar
Former Sponsor
You would have to do some work to make that fit on the rear especially.
Old Oct 29, 2009 | 04:25 PM
gtg749m's Avatar
Originally Posted by jonner,Oct 29 2009, 04:50 AM
17x8 +47 front
17x9 +44 rear
search rpf1. there is like a 100 page thread on that. most guys in there are running x8+45/x9+45. i know they are not the same but they seem pretty close to what you are looking at.
Old Oct 30, 2009 | 03:20 AM
jonner's Avatar
I was told that it should work with a little bit of fender rolling and with the stock suspension...????
Old Oct 31, 2009 | 04:13 PM
Vik2000's Avatar
just fender roll would be enough... 9 +44 isn't that bad
Old Nov 2, 2009 | 03:17 AM
jonner's Avatar
Would it need rolling on the front and rear..???
Old Nov 2, 2009 | 03:56 AM
BearNVa's Avatar
Do both yes that way you don't have to worry about it later....
Old Nov 2, 2009 | 04:29 AM
jonner's Avatar
Will do so.....
Old Nov 4, 2009 | 03:05 AM
jonner's Avatar
Any idea what tyre sizes to run with this set up..????
Old Nov 4, 2009 | 03:59 AM
ZDan's Avatar
I think you might be able to run stock AP2 sizes: 215/45-17 front, 245/40-17 rear, without rolling the fenders, just with some negative camber. If you're on stock suspension, have the alignment shop max out front and rear camber, should put you in the neighborhood of -1.3F/-2.2R. IMO that's not excessive and doesn't lead to ridiculous wear issues. I go with zero front toe and -.2* per side, -.4* total for the rear. That's what I've run for the past few years, and I get even wear.
