wheel fit
Old Jan 9, 2014 | 08:39 AM
toolowap1's Avatar
Default wheel fit
i am currently running 17x9 +25 with my fenders rolled on the front and would like to know if i would be able to fit 17x10 +15??? i've seen 18x10 on the front so im curious..
Old Jan 9, 2014 | 08:46 AM
1nate7's Avatar
No.
On the other hand, it might work with a 175 width tire and -6 camber.
Old Jan 9, 2014 | 09:05 AM
toolowap1's Avatar
Originally Posted by 1nate7
No.
but i would be able to do 9.5?
Old Jan 9, 2014 | 09:12 AM
Manga_Spawn's Avatar
Site Moderator
You currently running a 205 on those 9's? No they don't fit. Your current wheels don't fit. Pretty sure you are just trolling anyways.
Old Jan 9, 2014 | 09:16 AM
toolowap1's Avatar
im running 205/40 on a 9 up front. i want to see if i can fit any wider...
Old Jan 9, 2014 | 09:26 AM
1nate7's Avatar
Width isn't the problem in this case, offset is. You can go wider but you need a higher offset, something like 9.5" or 10" +50 with a 245 tire would be reasonable.
Old Jan 9, 2014 | 09:39 AM
s2000Junky's Avatar
Old Jan 9, 2014 | 09:43 AM
Site Moderator
No point in going wider if you are just going to run a narrower tire. 205/40 is not only way to narrow for a 9 inch wide wheel it it is shorter than stock as well. Like I said your current wheels don't fit at all so making them wider and lower offset won't fit.
Old Jan 9, 2014 | 11:01 AM
Bullwings's Avatar
I'm going to suggest the following
-Remove front fenders
-Plasma cutter rear fenders
-buy suspension from FOX RACING
-Buy wheels from American Racing or Pro-Comp
-Buy tires from Mickey Thompson
Old Jan 9, 2014 | 11:23 AM
Site Moderator
Lol and the worlds first Baja S2000 is born! I can only imagine how slow this car would feel with giant dirt tires and no torque to move them.
