Wheel fitment
Old May 12, 2013 | 01:18 AM
philipminge's Avatar
Default Wheel fitment
Hey guys n girls,
i have posed up a few things about wheels in the past. i have now changed my mind.
I currently have a stock body set up and the car is on KW V3 shox.
i am thinking of rolling my guards front and rear and also flare the rear slightly.
i want to run 17x9 with 255 all round.
i am not sure of offset??????
also not sure if i should run a 9inch wide or 8.5 inch.... i deff want to run 255's.
any help appreciated.
whaat offsets on rear? +55?
any rim and tyre experts around?? lol
cheers
Old May 12, 2013 | 01:44 AM
nadeem's Avatar
IM running 17x9 + 35 square with 255 re-11 and love it. rolled fronts and rears w/ tab relocation w/ 3 deg. camber square and your fine.
if you want to be safe just run +45, car will look flush, not aggressive and you can run 255 easily.
Old May 12, 2013 | 02:53 AM
thanks man, but whats square mean.
and also what is this bumper relocation thing people talk about??
camber will be around REAR: -2.3 to -2.5 front : -2 to -2.2
any pics of your setup?
cheers
Old May 12, 2013 | 02:54 AM
also you say easily.... would a 265 fit on a 9.5 wide rim? Just a question... lol
Old May 12, 2013 | 04:04 AM
01S2KSA's Avatar
Most people that run for example the RPF-1s in a square setup use the 17x9 +45 with 255s. The +45 will give you the flush look and depending on the tires that you are running (Summer, All Season, etc) will be the amount of camber needed once you pull and relocate the bumper tab. I personally and running a staggered setup with 17x9 +45 in the rear with a 255/40 and Im at about -3.1 camber. I am running all seasons which doesnt have as much of a square setup on the tires as your summer tires so I could adjust my camber back slight about a degree and be fine. I am running 17x8 +40 in the fronts with 215 tires with plenty of room with a roll and pull.
Try this to figure your tire sizing: Will They Fit
Old May 12, 2013 | 04:25 AM
thanks for the info man.awesome.
also thats this tab relocation.... do you have any photos? or links.
cheers
Old May 12, 2013 | 06:05 AM
01S2KSA's Avatar
DIY Rear Bumper Tab Relocation
Old May 13, 2013 | 04:44 AM
sweet as. will be doing this on the weekend prob.
also would you put a 255 on a 9inch wide rim or 8.5 inch wide??? note: will be for Track use
Old May 13, 2013 | 07:44 AM
Manga_Spawn's Avatar
Site Moderator
9 is better for a 255.
Old May 13, 2013 | 05:08 PM
s2000Junky's Avatar
And a 10" is even better then that
Dig1tal Ali3n
Aug 20, 2014 02:25 PM
steve695
Dec 30, 2012 06:33 AM
redbaron
Jun 28, 2011 04:26 AM
Moddiction
Feb 2, 2011 07:18 PM
oranje
Dec 17, 2008 05:01 PM
