wheel fitment
Old Apr 7, 2008 | 03:28 PM
babowc's Avatar
Default wheel fitment
should be an easy fit with coilovers, no?
I'm thinking 225/40 front and 235 or 245/40 rear..
wrong sizing!
it was 8Jx18+43 8.5Jx18+62, lol
what are some of the more "extreme" setups running around here?.. now that i look.. this isn't extreme at all, hopefully it wont be sunk?
I'm too lazy to search.
Old Apr 7, 2008 | 03:37 PM
AP2's Avatar
AP2
that fitment sounds safe to me. im a little worried about the front, depending on how low you are and fender mods, but if you run that 225/40 your thinking about, you should be ok.
Old Apr 7, 2008 | 04:00 PM
1nate7's Avatar
The front is going to need the fenders rolled and probably some extra negative camber dialed in, the rear is fine. Those seem like strange sizes, the front offset is much more aggressive than the rear. You could probably run a 255 in the rear without any problem.
Old Apr 7, 2008 | 04:23 PM
babowc's Avatar
hm.. i thought that's how the S is?
40ish up front and 60ish out back.
isn't stock something like it minus the widths being 7*/8.5? AP2
do AP owners usually remove their fender liner as well??
Old Apr 7, 2008 | 04:38 PM
Project22a's Avatar
Stock AP2 front is 7 +55. An 8 +43 extends 25mm (about an inch) further out that stock. you may need some sort of fender work or extra camber to make this work.
The rear will be fine without modification.
Old Apr 7, 2008 | 04:49 PM
babowc's Avatar
Ya, i was thinking i'd need camber for the fronts..
hmmm.. rears seem like it'll fit real easy.. maybe a 10 or 15mm spacer with some camber..
Old Apr 7, 2008 | 04:55 PM
Dressed2Kill's Avatar
Thats a strange setup. Your fronts will stick out 12mm more than your rear wheels.
Old Apr 7, 2008 | 04:56 PM
babowc's Avatar
Indeed..
I think I need to run some spacers in the rear.
Old Apr 7, 2008 | 06:01 PM
tampas2000's Avatar
you may want to go with a 205 or 215 up front.. i have 18x7.5 +43 offset and i rubbed a little on corners... go with 255 in the rear
Old Apr 7, 2008 | 06:02 PM
babowc's Avatar
how much lower are you in the front??
