Wheel fitment?
Old Apr 19, 2011 | 03:48 AM
slo ap2's Avatar
Default Wheel fitment?
Just curious, how much work it would be to make these fit? I'm running downforce front fenders, so I'm assuming I shouldnt have an issue with the front, but what about the rears? Currently my rear are only rolled and running -3.5 for camber. The wheels I am looking at have a hefty price to em, so I would hate to place an order if its gonna be a pain to run.
Old Apr 19, 2011 | 08:36 AM
05APdeuce's Avatar
It can be done with a bit of fender work and alot of camber in the rear. a buddy of mine is running 18x11.5-37 in the rear and he has minimal fender work done. but alot of camber and a 245 tire
Old Apr 19, 2011 | 11:48 AM
clarkster009's Avatar
Just go all out and get overfenders...and run a 275. What wheels?
Old Apr 19, 2011 | 10:51 PM
slo ap2's Avatar
Im looking to put an order in on a set of advan rz-df. I may go with the 18x10.5 +25 for rears if I decide to do rear over fenders. and bump the fronts up to 18x10 +35.
Old Apr 20, 2011 | 12:11 AM
estooki's Avatar
Probably can pull it off with the work you have done already but it depends on your tire size
Old Apr 20, 2011 | 01:32 AM
slo ap2's Avatar
Well, I don't want to have to run to much of a stretch on them. I would like to run 255's at the least. I may opt for asm rear over fenders and run a proper tire for the rear.
Old Apr 20, 2011 | 05:52 AM
I don't know what you mean by proper tire sizes, but even with ASM overfenders, don't think you're going to be able to pull of 18 x 10.5 +25. There is a guy running 17 x 9.5 +22 with 265 and he had to do all kinds of work to fit that...shave the overfenders, run like -3.5 or -4.0. I think the 18 x 10 +35 would be more ideal.
Old Apr 20, 2011 | 07:50 PM
DFWs2k's Avatar
I have 18x10+45 out back w 275/40 tires and -2.8 camber
if you go with a more s2000-esque profile, I don't think you'll have that much of a problem
Old Apr 20, 2011 | 08:11 PM
slo ap2's Avatar
Well when I say proper tire I just mean I don't want to run a 215/225 tire on that wide of wheel. I realize the ideal would be to go with the 18x10's all around, but I already have a set of 17x10's all around. Offsets are not as low. These would also not be daily wheels as these would be the 3rd set of wheels that I order. I'm just trying to get an idea of if I'll be able to run them or not, or if I'll need to go with rear overfenders.
Old Apr 20, 2011 | 08:12 PM
DFWs2k's Avatar
if you want to be slammed and run semi-wide tires, then yes you will need rear overfenders
