Wheel Fitment Guide
Then you have the width of the tires and your alignment specs will determine what will fit and what won't. There is no hard set rule on width and offset. The shape of the spokes can cause one wheel to hit and one to clear even in the same width and offset. Negative camber and the specific tire also plays into it as well. So I would use these sizes and offsets as a starting point. Especially when you are pushing the envelope..
i do not necessarily want squared wheels im just asking what is better to get bcs that wheel in 17x7.5/8 comes in 48 offsets only so im worried it will rub with 225 with car being lowered ,and i kinda do not see point buying new wheels to be same size as factory and narrower then what i have now .i hope this makes sense
Close to pulling the trigger on some wheels, just wanting to do a final check before I put in my order.
Work Emotion CR 2 piece
17x9.5 +54 Front, 17x10 +55 Rear
245/40 Front, 255/40 Rear
Lowered 1 inch on spoon springs, will roll front and rear fenders.
What camber would be recommended? Any other issues with fitment?
Looking for Volks OG TE37
17x9 +34 Offset square setup
I'll be running Ohlins Coilovers
I know it's an aggressive fitment however it seems they are pretty similar to the Evasive's TE37 fitment, besides rolling fenders and camber adjustment what else need to be done to get them fit on an AP2
Thanks for your input
17x9 +34 is really pushing it in the front. The front would need a pretty good pull (17x9.5 +41 would as well). They can fit in the rear but the front is much more difficult. Can't say I would recommend it.
Would I run 17x9 +34 with 245? Nah. 17x9 +34 with 215? Sure.
