Wheel Issue
check if the tires are the same size and if it is, then swap it to the other size but check the offset on the rims to see if they are the same. If the offset are the same and after you swap the wheels and the driver side still stick out like before, then you probably need a alignment. maybe you have more toe out on the driver side. Good luck.
