Wheel spacers
There aren't any with extended studs on the spacer for 5mm.
For 10mm, it depends on whether it's front or back because of different center bores. Here are the 2 I've personally used:
http://www.evasivemo...cs_Wheel_Spacer
The 2nd one is for the front with 70mm center bore. You're still going to have to make sure that the wheels you're using have enough space for the other studs that will stick through. I couldn't use the front ones with my 17x9 +45 RPF1s for example, because the other studs on the hub would hit the backside of the wheel.
