Wheel spec
Old Mar 31, 2011 | 12:46 PM
dipset chink's Avatar
Default Wheel spec
Hi guys. Just a quick one. Would these wheels fit onto a s2000?
Rim Width: 10J Fronts and 11.5J Rears
Rim Diameter: 18
Rim Structure: Three Piece
Offset: ET63 Fronts and ET70 Rears
Stud Diameter: 120.6
Number of Studs: 5
Old Mar 31, 2011 | 01:35 PM
gCHOW's Avatar
This is in comparison to oem AP2 wheels...
Front:
The clearance from suspension to the inside of the wheel will be 46 mm LESS
The outside edge of the wheel will EXTEND an extra 30 mm
Rear:
The clearance from suspension to the inside of the wheel will be 43 mm LESS
The outside edge of the wheel will EXTEND an extra 33 mm
im gonna lean towards no..
you're gonna have issues on the inside so you'll probably need spacers to push the wheels out.
then, assuming you are lowered, you're gonna run the fender for sure.
Old Mar 31, 2011 | 01:50 PM
So what kinda spacers am I looking for front and rear? And yes I'm also lowered on rsr springs, so say I get all arches rolled, everything should be alright?
Old Mar 31, 2011 | 04:22 PM
1nate7's Avatar
Won't fit, bolt pattern is wrong. That is a Corvette fitment, we need 5 x 114.3 (4.5).
Old Mar 31, 2011 | 05:48 PM
Mar48's Avatar
yea that's too bad because I think you would have been able to make those fit although like gchow said the rears would possibly need spacers... but anyway pointless thread since the wheels are 5x120
Old Mar 31, 2011 | 10:00 PM
DFWs2k's Avatar
just get them redrilled
rudyy
Sep 30, 2018 07:22 AM
Nberry95
May 19, 2015 07:32 AM
dsddcd
Jan 1, 2010 08:13 PM
JAPCAB
Jan 27, 2007 06:51 AM
[AP2-2NV]
May 31, 2006 08:20 AM
