Wheel Studs / CE28N Stickers
Hello guys,
Bought some used CE28N and one of them needs sticker replacement. Where can i find this in EU or US?
When the wheels were installed the guy in shop told me that one of my wheel studs screw is "passed" so it cant be used. One of the wheels is only stuck with 4 lugnuts instead of the usual 5. How can i fix this? To replace with completely new wheel studs more resistant and bigger the change is expensive/hard? What needs to be replaced? If i only replace the one that is passed the process will be easier?
Thanks!
Thanks!
Hello guys,
Thanks!
Thanks!
replacement wheel stickers for CE28 here: http://www.rhdjapan.com/rays-volk-ra...ticker-bk.html
I'm not sure what "passed" means, but if the stud is cross-threaded and beyond repair, then you need to replace it with a new stud. that requires removing the hub from the car so you can remove the old stud and press in the new one. You may also need to get a new wheel bearing too, as those tend to go bad when the hub is removed.
Yes, passed i wanted to mean cross-threaded. I will check if it is possible to repair the stud witouth removing the hub etc. If not probably will apply ARP Extended and more resistant Studs.
One more question guys.
For VOLK CE28N 17" and s2000 fitment the Hub Rings must be :
Front 73.1 MM x 70.1 MM
Rear 73.1 MM x 64.1 MM
Is this correct?
Metal, alluminium or plastic. What is the best option?
Thanks
Is this correct?
Thanks
SpeedxRacer
Oct 6, 2004 01:37 PM
