Wheel / tire suggestions
Old Dec 2, 2005 | 08:53 AM
2QYK4U's Avatar
Default Wheel / tire suggestions
I am interested in getting some 18" Volk GT-Cs (gunmetal centerpiece, polished lip) for my '06 S. I would like 18x7.5 (front) and 18x9 (rear) (18x8.5 at the least) so that I could run 225/40 18 (front) and 255/35 18 (rear). Well, the GT-Cs are only available in 18x7.5 +50 (front) and 18x8 +50 (rear).
Any suggestions?
Old Dec 2, 2005 | 09:12 AM
spa-zz's Avatar
Looks like you answered your own question, no?
You said you want a min of 8.5 in the rear but that the GT-C is only sold up to 8.0.
So that either eliminates that wheel, or eliminates the width you want.
Old Dec 2, 2005 | 09:16 AM
SIIK2NR's Avatar
It's hard to go wider wheel in the rear with only a +50 offset. If you get a better offset you can go as wide as 18x10.
Old Dec 2, 2005 | 10:08 AM
2QYK4U's Avatar
I am looking for feedback like:
Sacrifice tire size and get the wheels you like...
Tire size is very important, look for another wheel...
etc...
Old Dec 2, 2005 | 10:09 AM
2QYK4U's Avatar
What is an "acceptable" offset for the rear wheel?
Old Dec 2, 2005 | 01:44 PM
spa-zz's Avatar
etc...
Well, with an 8" wheel you could squeeze a 245 on the rear, and use a 205 or 225 on the front. If that's wide enough for you, go for it.
Personally it would bother me to get a nice set of aftermarket wheels that are narrower than the stock wheels, especially on the rear. If anything, you'd like to go wider for a more agressive look and more grip. But if you're mostly doing this for bling, who cares? Get the wheels and enjoy.
Old Dec 2, 2005 | 01:48 PM
spa-zz's Avatar
The offset is linked directly to the width.
On the rear, roughly, you need a 40 offset minimum for an 8" wheel, 46 for 8.5", 53 for 9", 59 for 9.5, and 65 for 10".
Old Dec 2, 2005 | 02:15 PM
2QYK4U's Avatar
Thanks for this information.
Old Dec 2, 2005 | 02:17 PM
2QYK4U's Avatar
No, I am not mostly doing this for bling. I am more interested in performance enhancements. Therefore, I'd like a wider wheel to accommodate a larger tire.
Old Dec 2, 2005 | 03:24 PM
spa-zz's Avatar
Then you might want to consider going down to 17" wheels and looking closely at the weight of the wheels you're considering.
