Why does it look different?
Old Feb 12, 2010 | 12:27 AM
stwokayyy's Avatar
Default Why does it look different?
Hey guys I just recently replaced the 16" oem wheels with some 17x7.5+50/17x9+63 wheels, im lowered on bilstein pss9's. I loved the stance with the 16" rims it was perfect, I initially thought the 17" wheels would make the car look a bit lower but it was the opposite it actually made the car appear a bit higher than the 16" wheels but I dont think it actually raised it because im still a solid 1 finger gap all the way through. my question is why does it appear that way? is it because im running a wider wheel? should I try to get a realignment and run some camber? or should I lower the car alittle more?
-Thanks
Old Feb 12, 2010 | 12:40 AM
modMonkey's Avatar
Most likely just your perspective given the lower tire profiles. It was the same for me when I upped to 17s. Out of curiosity, what are your tire specs?
Old Feb 12, 2010 | 01:07 AM
stwokayyy's Avatar
im running a 225/255 on my current set up, my 16" oem where the potenza s02's which i believe are 205/215 correct me if im wrong.
Old Feb 12, 2010 | 01:17 AM
TopGear's Avatar
225/??/15 and 255/??/17
I think modMonkey was probably interested primarily in the aspect ratio
Old Feb 12, 2010 | 01:20 AM
stwokayyy's Avatar
Oops 225/45/17/255/40/17
Old Feb 12, 2010 | 01:21 PM
stwokayyy's Avatar
Bump
Old Feb 12, 2010 | 01:25 PM
modMonkey's Avatar
Your profiles look right. It's just perspective. Alignment and camber, while important in it's own right, wont do too much for the way it looks
Old Feb 12, 2010 | 01:29 PM
Booch's Avatar
What was the complete sizing of your 16" tires?
Moving to the 17" rim would raise your car around 1/2" (since the radius of your rim changed 1/2") assuming your sidewalls were the same height as your 16's. Most likely your 17" tires have a slightly larger sidewall height, thus raising your car a bit more off the ground.
Old Feb 12, 2010 | 05:59 PM
stwokayyy's Avatar
my sizing of the 16" tires are 205/50/16 and 225/55/16 im probably just gonna try and lower it a little more and see how that looks.
Old Feb 13, 2010 | 05:15 AM
zdave87's Avatar
Member
If you have a model 2005, aren't your OEM wheels already 17"?
