Will 17x9+45 fit?
Definitely need to roll the fenders a good bit, relocate the bumper tabs and run some decent neg camber for them to not rub when lowered. I have 17x9+44 all around. 255's in the rear. I rub once in a while on a big bump. I have neg 3 camber in the rear. Might raise it slightly so I can run a little less neg camber.
17x9+44/45 I think is the best looking offset and width. Looks really aggressive without looking like some hellaflush hardparker.
Yeah it sounds like a perfect balance between having stance and performance. I could even go as far as +48 I guess.
The black and gold theme you have going there is awesome.
I won't quote so we don't get more giant pictures, but thanks. I hear that if you get the 9 inch wheel in the front, you will be fine as long as you don't go with big tires on the front. A local is running 225s on a 17x9+45 w/o issue.
Thanks.
13.6 is a very impressive time for the mods you have, are you using an engine management system?
I'm sure it does in some way, but you should be fine if you don't stretch them too much. Why have you chosen those sizes? There are very few tire options at 235/45/17 compared to 225/45/17. 245s aren't bad though, although I'm not sure if you can fit 245s on the front without running extra camber.
Either way, I'm a month or 2 off being able to afford new wheels, just doing the research now as I like to spend a good amount of time on these things. I wish I got it right the first time but I did not fully understand offset when I bought my first set of wheels.
