will this fit?
Old Jun 7, 2005 | 07:45 PM
SimbaDogg's Avatar
Default will this fit?
ok...simple question, the fronts look fine
the rims is 17 x 7 w/ 50mm offset...
but in the rear, problem. there's a 17 x 8 + 45 mm, and a 17 x 9 + 45...i know its bad, but how bad is it? will either of those rears work?
Old Jun 7, 2005 | 08:14 PM
ASMspec's Avatar
17x8 +45 will work with a 235/40/17 for daily driving commuting. Anything more than that with over a one inch drop you will have rubbing issues. I would go with the 17x9 but I would stick to above +50 on the offset so you can run wider tires.
Good luck.
Old Jun 7, 2005 | 09:50 PM
SimbaDogg's Avatar
i'd wanna run the ap2 sized tires on the rims
215/45/17 front, 245/40/17 rear. i know the front will fit w/out any rubbing issues. But what size should i go with for the rear to minimzing the chances of rubbing? the 8 inch or the 9 inch if i were to go w/ these rims...the highest offset they have in the 8 and 9 inch is 45
Old Jun 8, 2005 | 12:10 PM
SimbaDogg's Avatar
anything guys?
Old Jun 8, 2005 | 12:18 PM
Jim@tirerack's Avatar
Former Sponsor
The best sizes for the wheels you are talking about would actually be 205/50R17 and 225/45R17. These tires are going to keep you in the same diameter as stock with the stagger front and rear.
Old Jun 8, 2005 | 12:25 PM
ASMspec's Avatar
I would have rubbed with a 245 at a 3 inch drop. Again go with 235/40/17 rears and you will be fine. If you go 245 thats 10mm more width wise so you will rub or come close to it. Thats all dependant on your drop of course .
millertown15
Jul 12, 2009 01:09 PM
f20c_rice
Oct 7, 2006 09:30 AM
drift86
Jun 4, 2006 08:16 AM
iNetForce
Apr 22, 2006 05:20 AM
tukluc
Jan 11, 2004 01:34 PM
