Will this fit?
Old Mar 14, 2012 | 06:21 PM
s2k_636's Avatar
Default Will this fit?
Any of you experts happen to know if I can fit a 17x9.5 +38 Work XD9 on the rear? I'm lowered on Buddyclub N+, Euro alignment, Rolled fenders and rear tab relocated. Thanks!
Old Mar 15, 2012 | 03:49 PM
1nate7's Avatar
It can be done. You would probably have to go more aggressive on your alignment, something like -3 to -3.5 rear camber. Also, 245/35 tire would be your best bet if you don't want to pull the fender.
Old Mar 15, 2012 | 07:02 PM
s2k_636's Avatar
^ Thanks!
Old Mar 15, 2012 | 07:05 PM
1nate7's Avatar
Whoops, it should be a 245/40/17 tire to keep stock diameter, not 245/35. For some reason I was thinking they were 18's.
Old Mar 15, 2012 | 08:18 PM
s2000Junky's Avatar
Yeah no problem. UK spec is -2 camber so that works for your set up with 245. If you wanted to run 255's you can, you would just need to go with close to -3, but that's doable.
Old Mar 15, 2012 | 08:57 PM
Froth.'s Avatar
It will fit, but you need a LOT of rolling and trimming before it will fit without rubbing. Camber will need to be adjusted depending on the height of the car, it's very tight with 9.5 +38 and a 245.
Old Mar 16, 2012 | 04:34 AM
Jim@tirerack's Avatar
Former Sponsor
I agree with the 245/40R17. It is tight but you already did what is needed to make it work.
Old Mar 16, 2012 | 08:06 AM
s2k_636's Avatar
Thanks everyone!! I can sleep at night now. Now its just a waiting game.
maxl
Jul 20, 2018 08:49 AM
express2000
Jun 21, 2016 08:04 AM
Rays S2k
Sep 13, 2013 09:30 AM
baZurk
Apr 6, 2013 08:25 AM
s200000
Oct 29, 2012 08:35 PM
