will i have rubbing issues? answer = yes
Old May 25, 2008 | 09:16 PM
stolitonic22's Avatar
Default will i have rubbing issues? answer = yes
will be running BBS LMs 18x8 +50 18x9.5 +55 225/40/ & 265/35 on RE01R's. i have koni yellows with oem springs ('02) so the car is dropped only .5 inch.
any thoughts and/or opinions on whether there will be issues with rubbing...
thanks
Old May 26, 2008 | 11:44 AM
Vanishing Point's Avatar
Review the wheel/tire fitment guide at the top of this forum, it has the info. you seek. Are you running the UK alignment?
Old May 26, 2008 | 12:08 PM
thanks... duh - i am such a bonehead. i will search and read a bit first the next time.
as for running UK alignment... am not sure what this means. currently have the AP1 US OEM specs for alignment.
Old May 26, 2008 | 12:28 PM
Run a search for the UK alignment, gives a little more room running more neg. camber. There is a lot of info. to digest in that forum, but it should give you the answer(s). I feel confident your rears will clear fine, the fronts may have rubbing on suspension compression where you are turning. A little added neg. camber might make the difference, hopefully someone will be along to give a better evaluation of your set-up.
Old May 26, 2008 | 01:11 PM
tampas2000's Avatar
thanks
you will be fine... i am running a similar setup.. the front might rub a little (you might want to go with a 215 up front)... i have the same wheel, tire & offset in the rear and no rubbing.. im on tein springs (about a 1 inch drop)
Old May 28, 2008 | 04:49 AM
Jim@tirerack's Avatar
Former Sponsor
I would say a little negative camber and maybe roll the fender lips. The 255/35R18 on the rear will be safer.
If I can help with package let me know.
Old Jun 3, 2008 | 03:19 PM
update - yes there is rubbing (in the rear)...
am trying to schedule for the rear fenders to be rolled.
in summary:
BBS LMs 18x8 +50 18x9.5 +55 225/40/ & 265/35 on RE01R's x Koni Yellows x OEM AP1 springs (on lower perch of Koni = 1/2 drop) = Rubbing
Old Jun 4, 2008 | 10:36 AM
i can't decide if i should get an alignment first then get the rear fenders rolled.
Old Jun 5, 2008 | 07:48 PM
AP1NYT's Avatar
Do you think that if you went with the 255/35 in the rear it would have fixed the rubbing in the rear?
Old Jun 5, 2008 | 08:15 PM
i think so... but the wheels i purchased from Dark_Sub_Rosa already had the 265s on.
i did have the rear fenders rolled moderately - but it needs to be rolled just a bit more.
