will these offsets work for the s2k?
Old Feb 19, 2006 | 01:33 PM
MINatSAR's Avatar
Default will these offsets work for the s2k?
i was wondering if the 17x7.5 +50 and the 17x8.5 +42 would work on the s2k any input would be helpful
Old Feb 19, 2006 | 01:46 PM
04RioS2k's Avatar
the front would work but the rear would probably rub badly....if sticking with stock ap2 tire sizes.....
Old Feb 19, 2006 | 02:49 PM
spa-zz's Avatar
An offset of 42 on the rear will cause rubbing with some 245 tires. Others have done it with no rubbing. I think it depends on what tire you choose. For instance, Toyo tires run narrow so they often fit. It would be safer to use a 225 on the rear, but then you'd have to run something really narrow on the front to avoid an oversteery S2000, which is a bummer.
Old Feb 19, 2006 | 03:16 PM
WyattH's Avatar
Front is perfect. Rear would need a 245 tire and some aggressive camber and some possible fender rolling. Possible, but not ideal.
Mizh
Aug 20, 2011 08:54 AM
GPWonTan
Sep 17, 2008 12:49 PM
wassapyo69
Sep 16, 2008 06:26 AM
street_ruler
Oct 16, 2007 12:51 PM
kentarou
Apr 17, 2006 06:19 PM
