Will these wheels fit my S?
Old Nov 29, 2004 | 01:46 PM
ctrlaltdelboy's Avatar
Default Will these wheels fit my S?
Hi guys
I have been running Volk TE37's on my NSX with 16x8" +40mm offset upfront.
NSX standard fronts are 16x7" +55mm offset, but the Volks are both recommended fitment and do fit just fine, however I am going BBK on the NSX and need to move up to 17" fronts.
so I was hoping I could recycle the 16's for the S whilst finding a suitable pair of rears to match.
so my question is, will these rims fit ok?
will they be out of the question, or just a tight fit?
if tight is that on the inside or the outside?
thanks for your help guys
Old Dec 1, 2004 | 11:16 AM
can anyone help me on this one then?
Old Dec 1, 2004 | 01:07 PM
evo s2000's Avatar
16x8 +48 up front? What size tire are you planning on running?
Old Dec 1, 2004 | 06:14 PM
s2konda's Avatar
Some people are running the spoon wheel up front which has an offset of 38...but I'm not sure how wide it is.
Old Dec 2, 2004 | 09:39 AM
thats 16x8" with +40 offset not +48
the wheels are currently shod with 225/45/16 Goodyear Eagle F1 GSD3s and are on my NSX
advice on whether I can get away with these would be appreciated - I could just jack up the NSX, get the wheels swapped onto the S and give them a try I suppose
Old Dec 2, 2004 | 11:04 AM
evo s2000's Avatar
16x8 +40 with 225 tires up front? Hm... I Never seen it done with this set up. I think it should most likely rub. Even you are running thinner profile tires.
As far as the Spoon set up. They rub unless you run 205 tires up front.
GuardianDevil
Feb 10, 2011 06:11 PM
llxzxll
Dec 15, 2008 05:19 PM
mugen888
Dec 10, 2007 02:05 AM
S2005x
Sep 9, 2007 08:07 PM
yellafeva
Jun 29, 2004 01:29 PM
