will this work
Old Jun 12, 2006 | 10:20 PM
wheresbao's Avatar
Default will this work
17x8+44 114.3 5h 17x9+44 114.3 5h
will this work
Old Jun 13, 2006 | 04:46 AM
DerrS2K's Avatar
If you run skinny tires, add neg camber and/or roll the fenders it will work. Not a very good set up, but you could make it work.
Old Jun 13, 2006 | 07:16 AM
Sinji's Avatar
run 2-2.5 degrees of negative camber in the back and roll your rear fender. you can still use 255 tires in the back
Old Jun 13, 2006 | 09:19 AM
wheresbao's Avatar
SO THE FRONTS WILL FIT AND ILL NEED TO ROLL REARS AND NEG. CAMBER?
AND TIRES SIZE RECOMMENDATIONS PLSE.
Old Jun 13, 2006 | 09:20 AM
Jim@tirerack's Avatar
Former Sponsor
I would just say there are a lot better options for wheels.
Old Jun 13, 2006 | 10:43 AM
DerrS2K's Avatar
You will have rubbing with both the front and back with that set up if you don't run neg camber and roll your fenders. Please read --> https://www.s2ki.com/forums/index.php?showtopic=342793 This will give you an idea of what fits and what doesn't. Tire sizes also play a large part in if it will fit or not. Again, much better options out there.
Smallest tires you could fit on an 8" rim in front are 215 and your offset is 4mm off so neg camber might fix that. Rear you are looking at 245 which is only 1mm off. But to keep the stock stagger (this is something you do want to do) and to optimize your 9" wide rear rim you would want 255 which is 6 mm off. Rolling your fenders and some neg camber should do the job. A couple mm sounds like it isn't an issue but it definately makes a difference.
Better off just buying rims that fit without messing with the car.
Old Jun 13, 2006 | 05:00 PM
wheresbao's Avatar
I SHOULD GET WHEELS THAT DONT REQUIRE MODS. BUT OLD SCHOOL BLITZ R NICE... THANKS 4 EVERYONES HELP...
Old Jun 15, 2006 | 09:30 AM
Former Sponsor
I think that would be a better idea. Those sizes and offsets would have been tough.
Old Jun 15, 2006 | 12:14 PM
jdm_rsx's Avatar
thanks for the link
it was very helpful = )
answered a lot of my questions..
pjf1985
Dec 15, 2013 10:41 AM
Christakis
Nov 7, 2012 04:56 PM
s200000
Oct 29, 2012 08:35 PM
f00dstamps
Jun 16, 2008 11:50 AM
lilmrtinnie
Mar 29, 2007 02:47 PM
