18x9 +42 will this wheel fit?
Hey guys,
I'm looking at some input into whether or not this wheel will fit. The rears are 18x9 with a +42mm offset. I will be lowering my car on Eibach pro kits 1"/1". Considering the factory camber of -1.5 in the rear and rolling the rear fenders, would I be able to use a 245 or 255 rear tire?
If not, How much camber do you think I would have to run to prevent rubbing?
I also understand that some tires are narrower than others. Do you guys have any suggestions for a narrow tire to run so.
My goal is to extend the life of the tire since this is my daily driver.
Sinji - so you're saying that i could do 245's if i don't roll the fender. if i roll the fender, could i do 255 safely with those camber specs you suggested? also, if i stick with 245's, and roll the fenders, would i be able to dial in less than the suggested 2 - 2.5 degrees of camber? i would prefer not to run more than 2 degrees of camber in the read.
jim - yes, i need suggestions for tires since i have not purchased them yet. wheels are 18x8 and 18x9 and i'd like to run a 225 front and 245 or 255 in the rear. thanks.
at first i didn't think i'd have a problem with the front but now i might. i'm looking to run an 18x8 with a +40, 225 tire, 1" lowering, and a preferred stock camber of .5 degrees.
keefss2k
Jul 31, 2013 07:34 AM
