will this work
Old Feb 4, 2011 | 05:24 PM
jdms2k_alex's Avatar
Default will this work
hey guys im going to be getting some rpf1's soon most likely in 17x9+45 non staggerd cuz i want them to be concave front and rear, and my question is will it be ok to run a 225 tire frnt and 245 rear? will that help even out the grip so i dont have oversteer? or should i just run same size tire frnt and rear? thanks guys
Old Feb 4, 2011 | 06:52 PM
ZDan's Avatar
Without commenting on whether or not it'll fit without a rub, lemme just say I'm not a fan of the look of 225/45-17 fronts (25" OD) with 245/40-17 rears (24.7" OD). 225/45-17 fronts don't look right unless you go with 255/40-17 rears (same height).
Personally, I'd sooner try 235/40-17 up front rather than 225/45-17. Wider, but significantly shorter (24.4"), maybe less likely to rub.
Old Feb 5, 2011 | 05:44 AM
Jim@tirerack's Avatar
Former Sponsor
I will tell you that it will take some work to make them fit. There are a lot of guys running that set up though. Some negative camber and maybe a fender lip roll.
If I can help let me know.
Old Feb 5, 2011 | 04:31 PM
k thx for the replys
jdmdohcpower
Feb 23, 2014 11:34 AM
THE GEWYIST
Sep 8, 2012 07:09 AM
candyteggy
Oct 14, 2009 08:58 AM
fishs2000
Jul 26, 2008 11:44 AM
skrudder
Apr 12, 2007 12:57 PM
