Work Emo Cr Kai + Spoon Cali
Ok just wanna check, check again, double check to make sure this will work.
I have the Work Emo Cr Kai 17x8 +47 at the front and after all the research i think i have this correct. If i want to use the Cr kai +47 with spoon cali i would need a +10mm spacer? Is this correct? I don't want to spend the money and find out that i need a higher mm spacer. Also if i was to do this i would have to roll my fender or do some high camber setting like -3 or something higher right?
Originally Posted by silentdancer,Feb 10 2009, 08:42 PM
if u get these wheels i suggest to roll the fronts and u definately do not need that much camber in the front unless you want to run a bigger tire size than 225
Although you "might" get away without rolling if you don't use the spacer. With the spacer, you have to roll, but I don't know if 17x8 +47 requires a spacer, I know the 17x9 +44 does.
Hmm well i don't really want to use spacers but from what i read the +47 Cr kais won't clear the spoon cali, so i guess i need spacers but i just don't know what size spacers
The Work Emo Forged is +42 and does no need spacers the style of it is exactly like the Cr kai, i don't know the diff between them i would assume i only need a 5mm spacer but i read somewhere else i would need 10
