work wheels please help
Old Apr 16, 2014 | 12:16 PM
Manga_Spawn's Avatar
Site Moderator
^Agreed. Not sure if it is available but Work has a Metal buff finish that is similar to the Enkei SBC finish that is amazing.
Old Apr 16, 2014 | 01:48 PM
ap2dylan's Avatar
[quote name='Manga_Spawn' timestamp='1397662061' post='23115438']
It's dropped close to 2 inches I think. Not tucking any tire but it's just above that.
[/quote
assuming you are on coilovers, what brand are they?
Old Apr 16, 2014 | 03:10 PM
Site Moderator
Yes I am on coilovers. They are Top Secret Aragosta Coilovers. All of this info in my build thread I posted the link to above.
Old Jul 7, 2014 | 07:57 AM
yoshii's Avatar
Originally Posted by Manga_Spawn
Personally if I was going to run these wheels I would get the 17x8.5 +42 for the fronts and the 17x9.5 +38 for the rear. Roll fenders relo tabs run 2 degrees camber front and 3 degrees rear with a 245 front and 255 rear.
Damn, pretty much read my mind!
About to pull the trigger on a set of D9Rs in those sizes (F: 17x8.5 +42 / R:17x9.5 +38) with tyres as follows (F: 235/45/17 / R: 255/40/17) however I'm a little unsure of how much guard work/modification will need to be done to get them to fit. From what everything I've read so far on here, 2deg front & 3deg rear and rolling my guards should be enough to run this setup without rubbing or anything right (depending on ride height as well)?
At the moment car is completely stock, after an upcoming track day (want to get a feel for stock before changing anything) is when i'll be placing the order for new wheels, tyres & coilovers. I guess before I lay out the $$$ for everything, can you (or anyone) confirm the above setup will fit/work properly?
Cheers!
eddiex
Oct 8, 2010 02:15 AM
SebRedAP1
Aug 29, 2009 04:22 PM
notyourfriend
24
Jan 20, 2009 08:26 PM
lautll421
Apr 7, 2008 06:23 AM
kidjetta
Mar 5, 2007 09:51 PM
