would these rims fit?
Old Feb 22, 2005 | 08:34 AM
greys2k's Avatar
Default would these rims fit?
Foose Lusso's
42++ offset
245/35/18 (rear) 18x8
225/40/18 18x7.5 (front)
I can get them for just under 2600 shipped all the way to Canada
or 1700 with no tires....what do you guys think??
Old Feb 22, 2005 | 11:13 AM
greys2k's Avatar
nobody?!!?
Old Feb 22, 2005 | 06:47 PM
greys2k's Avatar
Okay if no one wants to answer that..then how bout this?? anyone know if the Foose Speedster's will fit??
18x7.5 x 2 for the front
18x8.5 x 2 for the rear
tires
225/40/18
245/35/18?
Old Feb 23, 2005 | 11:59 AM
greys2k's Avatar
Somebody please!?!?!?!?
the rim has a 34++ offset
Old Feb 23, 2005 | 05:25 PM
xviper's Avatar
You've not mentioned anything about lug pattern, but for now, I'll assume you know those are correct.
+42 offset, 7.5" wide and 225 tires will stick out and rub when the suspension is compressed (bumps or hard turns).
+34 offset is way too little. Again, they'll stick out rub.
Old Feb 23, 2005 | 08:14 PM
greys2k's Avatar
well the rubber can be whatever, my largest concern is if the rim itself will work
they are the correct bolt pattern (5x114.3)
Old Feb 23, 2005 | 08:25 PM
s2ka's Avatar
You'll rub with those offsets, and they're gonna stick out past the body.
Old Feb 23, 2005 | 08:30 PM
greys2k's Avatar
I can find the foose speedsters with a 45mm offset would this work?!?!?!
tires still 225/40/18
245/35/18 or what!??!
18x7.5 and 18x8.5?!?!
thanks a lot!!
Old Feb 23, 2005 | 08:34 PM
xviper's Avatar
thanks a lot!!
They will stick out.
Old Feb 23, 2005 | 11:14 PM
s2ka's Avatar
See if you can get them in 55mm offset up front and 65mm in the rear, otherwise they'll stick out and rub the fenders.
