Would these wheels fit the S?
Old Jun 2, 2003 | 09:00 AM
MintyWinty's Avatar
Default Would these wheels fit the S?
ADR Kasai Rims
Bolt pattern fits, but not sure about the offsets. Could someone help?
Front - 17x7 (38 offset)
Rear - 17x8 (45 offset)
If these do fit, what tire size would you recommend?
These rims look just like the Advan model 5 wheels, but a lot cheaper.
Thanks!
Old Jun 2, 2003 | 03:18 PM
Kendo's Avatar
I think the offset is going to be too aggresive. If you are going to do 7
Old Jun 4, 2003 | 04:16 PM
S2K1's Avatar
They will fit, but they'd stick out a little bit. These offsets would not allow very wide tires without rubbing or sticking out further.
Old Jun 5, 2003 | 01:47 PM
Jim@tirerack's Avatar
Former Sponsor
At the most you would run a 205/50R17 and 225/45R17. I have my doubts on the front wheels though.
Jim
Old Jun 6, 2003 | 05:28 AM
S2K1's Avatar
I've run 40mm offset wheels front and rear before and the fronts barely cleared the caliper with less than 1mm clearence. I wouldn't suggest going below that, but if you want it, go for it.
Kengthao91
Jan 22, 2013 09:30 AM
marquez617
May 25, 2012 07:07 PM
BLanham
Apr 21, 2008 05:59 PM
S2005x
Sep 9, 2007 08:07 PM
siapao
Oct 4, 2005 01:28 AM
