WOULD THIS WORK
Just to let you know, when you type in UPPER CASE, that means your YELLING. But back to the subject...
if your running a 18x8 +45 in the REAR, then yes, you will be able to fit that 245 you want.
And as far as the fronts, no they are not going to work. you need a wheel with atleast a +53 to run the 225's up front.
Hope this helps... and about the rolling, i don't think you will have to in the rear. Either way, it will be close. Roling isn't a big deal anyway, i've done it to my last 3 cars without any problems.
ESCALVANTE
Jul 26, 2008 12:31 PM
REAR= 18+8 OFFSET 42 OR 45 TIRES= 245 35 18
