18" Tire size suggestions
I am running a Staggered setup: 18x8 +55 fronts and 18x9.5 +62 rears. My old tires were 225/40 18 front and 255/35 18 rear with no fender roll or pull and was lowered 1.5" and no rubbing. My question is will I rub if I run 235/40 18 fronts and 265/35 18 rears lowered at 2" with fenders rolled and a slight pull.
Any advise regarding this matter is greatly appreciated. Thank you.
Former Sponsor
With that offset you should be fine. I would run more negative camber with the car lowered and that should be it. If I can help with the tires or suspension let me know.
I have an 18" tire question as well. I have 18x8 and 18x9 +45 wheels. I will roll fenders and tab relocate, i want to sit flush with no fender gap. I was going to run 215/40/18 for front and 245/35/18 for rears but due to selection availability being an issue for the brand I want, I was wondering if I can run 225/40/18 front and 255/35/18 rears without any problems?
What’s the biggest tire setup for 18x8.5+35 for front and 18x9.5+30 in rear. I’m going fenders rolled and that’s about it. Dropping a little bit to where there’s little to no rub. Any suggestions??
