5mm spacers and their lack of 'hub lip'
#21
^^^Good info. At first glance that caliper looks like my trophy. Is the ST43 a slimmer design then all others that makes this fit possible? A good buddy of mine is pretty firm on not wanting to touch his fenders, but would like a BBK ideally. Will pass this info on to him. Wheel choices are tough enough with stock fenders, and introducing a BBK into the mix just seems impossible. I'm impressed you are also able to run a 255 up front and being lowered to boot without rubbing. This all isn't a combination that would have thought even possible. Id probably steer him towards a 225 or 245 up front for some added safety margin. He does prefer a stagger anyway. Myself, well im sure you have heard of my fitments
(photo cred goes to adrs2k lol)
Here's a link to the kit I have: https://v8roadsters.com/product/v8r-...43-trophy-kit/
All of the known wheel fitments are posted in there as well. I was considering running a narrower tire up front for a slight stretch, but I do know that Adam is able to make it work. I'm not going to be stupid low, probably no more than 3/4", and I'll be running around -3* of camber out front, but we'll see. Something about a meaty tire that really gets me. And yeah I know all about your specs and fitment hahaha.
#22
^^^ No the trophy is also 4 pot for the s2k. Looks identical to that one at first glance. I think the st43 is slightly lighter weight so must be slimmer in places, as i recall seeing a thread on it. Either way i think they are about the same cost, so might as well go with the st43, if fitment is a big issue. Thanks for the info
#23
Just to raise awareness, i measured the oem security lugnut bolt weight. Turns out it is about 20grams heavier than the 4 other oem bolts per wheel. Thats 20grams of rotating weight that is unaccounted for. Will it make absolutely any difference on ride quality? No. But it definitely wont hurt it. Main reason for removing the 4 security lugnuts for me was i hated keeping track of the security socket. That and changing between 19mm socket and special socket per wheel got annoying quick. Now i can remove all lugnuts with just a 19mm for convenience sake. And i doubt anyone wants to steal 17" rims nowadays anyway.
#25
#26
The STR43 as pictured above is a new Stoptech caliper, but it is only available as part of the V8Roadsters kit. It is a trophy caliper (motorsports line), but its smaller overall, holds 20mm brake pad, and is almost half the weight of the current ST40 based Trophy Kit. STR43 kit was designed to be the most offset friendly BBK on the market all while not sacrificing any performance.
#27
Cool thanks for the info. Sounds good in theory on them holding up. Thermal capacity at the track is the primary reason for running a BBK, hence the BIG in BBK. If the calipers are smaller and lighter and can still withstand the heat and abuse at the track, than seems like a winner. I imagine most the weight savings is in the rotors.
#28
How could they shave half the weight off the caliper and have it be effective at alleviating heat transfer and also be stiff? Id have to see them side by side to see how much smaller the caliper is/where the material is shaved from. Didn't think there was much left of the caliper to trim after the standard ST40 to trophy caliper revision. That's why I was thinking a lot of it has to be in a smaller/lighter rotor package, but again too small/too light and its no longer in theory an effective BBK. At some point the only benefit going to this from stock is the 4 piston.
#29
I have zero concern about the smaller and lighter STR43 having any issues managing heat and its already been used and abused on track during development. The STR43 uses a 328x28mm rotor...so still a big rotor .
#30
Nice Well I very may have considered the STR43 over the trophy if it was available 2 years ago. But it wasn't, and the trophy like the STR43 is a beautiful looking piece of manufacturing that does as it was intended, even if its not as light. I don't mind a little overkill, that's kind of the whole point of my car anyway lol. At least its lighter and stiffer then the base ST40 caliper, as it should be for another roughly $500 for the kit.
