ASM rear flares with IG V1 fronts
ASM rear flares are 25mm and the IG V1 fronts advertise 30mm
im looking at some Advan RZII 17x10 +50
I thought I read this to be a good spec for the ASM rears, was wondering what you thought about the extra 5mm upfront and what tires?
6.2 ls3 swap. Looking for extra meat with the tires but want a “conservative” flare option/appearance.
Thanks! ... I really suck at wheel fitment.
Ya, researching back into the threads its seems like it would be better in the +38-40 ??
I was checking DF fenders because they advertise same 30mm as IG. And also looking at the ASM flares.
Site Moderator
I run ASM rear flares and Dorwnforce fronts. Wheel specs are 17x9 +43 with a 245 front and 17x10 +35 with a 255 rear. 17x10 +50 needs rolled fenders but no need for flares to fit those. I don't know what IG stands for?
If your goal is functionality over maximum outer flushness, then yes on those tires and wheels spec and you will have enough room to run a 275 up front too if you want. In all rights you still have a little outer room to play with front and rear, about 10mm. So you would be safe to run a +40 if those wheels come in that spec. Otherwise there is the spacer option. Or just leave alone. Of course if it were me, Id be running a wider rear wheel to accommodate a 315
Im thinkn of running this in the rear at either a 10.5 or 11” wide. Witg ASM rears a +35 offset would work?
If I decide to stay 17” does that change the offset I want or can safely run?
With these fronts what offset should I shoot for? I dustry garage V1 flares. Thanks all. Max width I can go is 9.5 because of swap outer tie rods and Eps re location.
for what it is worth i will be running 18x10.5 +25 konig hypergrams wit ha 285/30 tire and asm rears. talking to some buddies online it works with the asm rears. this is robert thornes 18x10.5 +22 and he said he runs both 285 and 295 width tires on this setup
thats niice. See thats what I think may be the difference between what works with a 17” and a different offset for 18” working well. That looks like the new spoon bumper to!
