F225/45/17 R245/40/17 8inch AA
Probably talked thousand times.
Is this setup ok in 8 inch wheels?
I have calculated tire diameter with Rob Robinette's android program (carcalculator) and rear wheel looks smaller.
But due to a straight tire I guess that the tire will be more stretch then... bigger?
245 40 17
Tire diameter : 24,71
Section width : 9.64
225 45 17
Tire diameter : 24.97
Section width : 8.85
What do you think?
245 40 17
225 45 17
What do you think?
Thanks for answering. Well probably 255 is too much for a 8inch tire so... I will have to choose 245 for rear? Rims are impreza sti's and I guess they are not exact 8 inch but 8.25
Kind regards
Kind regards
Originally Posted by S_DosMil' timestamp='1471758384' post='24044190
If you have. Square setup why not just run 245/40s all the way around?
245/40/17 all around?
Nankan ns2r 120 compound.
This wheels go from 225 - 235 to 255.
Now am running a allarround 225 set and I feel that 225 is too narrow for rear. With the puddy4.77 corner acceleration is difficult in second gear...
