PF01SS Squared Setup
Old Oct 13, 2018 | 04:50 PM
brc80's Avatar
Default PF01SS Squared Setup
I really like the look of the SS with the bigger lip.
This being a 100% street/weekend car. I was thinking of going,
Front 245/40/17 & Rear 255/40/17
Would that setup be fine on a 100% stock car, or would I still run into issues?
If so I will go with the staggered setup.
Thanks for the help.
Old Oct 13, 2018 | 08:14 PM
P-Dub's Avatar
I run Front 245/40/17 & Rear 255/40/17 on a street car w/ no issues. Wheels size is 17x9 +61. Next time I'll do 255 square.
Old Oct 13, 2018 | 08:53 PM
brc80's Avatar
Are you lowered at all. Im thinking at some point a may go with a slight drop.
Old Oct 14, 2018 | 06:58 AM
PureFunction's Avatar
The 17x9 +60 can work with stock fenders. i still got an occasional rub in the front when i wasnt super careful going into driveways(with a 255/40 and lowered about 0.5-1 inch). So i ended up rolling the fenders to be safe. I have the 17x9 +48 in the rear and that required a roll and tab relocation.
Old Oct 15, 2018 | 07:35 PM
zpeed's Avatar
I got 245 all 4 with 17x9 +48. The rear is flush really nice with the body. The front is poking out a little. Next set I'll go 235 in the front or get a pair of 17x8 or 17x9 +60.
My car has about 1" drop. I have to roll all 4 corners.
Old Oct 16, 2018 | 07:42 AM
brc80's Avatar
When you say the front is poking out do you mean the tire or the wheel?
Old Oct 16, 2018 | 07:29 PM
zpeed's Avatar
Both wheels and tires with 245 on 17x9+48. I did put a bar on the side wall (vertical) and measure the gap. It's about half an inch out. The wheels are about 3/8" out. The back is nicely flush. Anyone have a pair of 17x8 or 17x9+60 to tread?
Old Oct 17, 2018 | 05:13 AM
Zissou's Avatar
I'm on 17x9 +63 TRMotorsports with 255/40r17 all around. Lowered on Fortune 500 coilovers. No rub.
Old Oct 17, 2018 | 08:48 AM
s2000Junky's Avatar
Yeah +60 range offset works on stock fenders up front if not lowered too crazy, but you get into the +48 you are going to have issues and need to roll your fenders. They will stick out, certainly if you are running near stock camber alignment.
Old Oct 17, 2018 | 08:49 AM
s2000Junky's Avatar
Will fit fine if they are the +60's.
