Are these wheel nuts good?
Has anyone got this? I want to hear some review and see if they are good. Thanks.
M12 X 1.5MM 20PC CNC WHEEL RIMS LUG NUTS FORMULA STYLE GUNMETAL RED W/ KEY HONDA
no, those look like they are made of Chinesium. avoid. hell, even the stock photo shows the threads already rusting.
check out Muteki, they are solid. they make several different styles.
Floating seat "formula style" lugnuts for $49.
I mean...they're steel, it looks like. So...they'll probably hold up. The floating seat likely won't. And I'd question the quality of machining.
**edit, they're aluminum. LOL no don't buy then unless you love dying.
Muteki is a solid choice. They're not as cheap or fancy. But your wheels will stay on.
Gorilla or other known brands of tuner nuts are also available.
Moved to W&T
For OEM wheels or aftermarket?
Site Moderator
Copies of the Kics lugs. I'd steer clear. Gorrilla makes decent cheap lugs. Muteki is great if you have a little more to spend. Lots of color options as well.
No way those are aluminum, I can tell just by looking at the chrome finish and the rust makes it even more obvious.
Sellers id ilovetacotaco doesn't help either
Found them on amazon with some reviews, just like the others said avoid.
I've been using these for nearly 2 years now on both street tires and r-comps. Love them and never had an issue thus far:
Black Forged Alloy Lug Nuts
