Tires rubbing fender bad... Need advice
I dropped my s2000 on coilovers probably about 2.2 inches yesterday. It's still on stock AP1 wheels which are far from aggressive, so I assumed i wouldn't need any fender work, I was very wrong. My fronts are rubbing the fender liner bad and chunks of my tire are falling off. I'm not driving the car anymore until I find a solution. What should I do? Im willing to do fender work just no pulling. Any advice would be GREATLY appreciated. Thanks!
Raise the car .75-1.5 inch would be your only option. A basic fender roll wouldn't even work since you're not even rubbing on the outer lip of the fender liner. I've never even heard of a case of someone rubbing on oem wheels (w/o spacers) until now, so your car must be on the ground.
Haha alright I'm just gonna take the liner out then because it's already torn to sh*t anyways. So to get this straight you can add camber to the front stock? My mechanic said that wasn't possible which didn't really make much sense.
you can also just trim back the liner in the places it's rubbing with a dremel tool. no need to remove the liner completely. there is only a certain amount of camber adjustment with a stock setup. it's unlikely but are you maxed out already? also curious to see a picture of you car. you must be crazy slammed to be rubbing like that with AP1 wheels/tires.
Picture of the car
To show how far the lip is from the ground
View of one side without turning the wheels... one of the guys at the shop I got them installed at did a little bit of modification to the liner which didn't really work and now I have loose fender liner... not a good idea
The other side is a little worse, turned the wheel so you can see the tire has been eaten in the spot of the rubbing.
Looks good trim liner and piggy back on what he said. Only some camber can be dialed in. Be careful tho my buddy just tore his fender out on stock ap1s slammed. I'd reccomend a roll to avoid future paint or body work. Car looks good on ap1s go for exhaust you'll love it.
Just saw chunks out of tire. Better roll asap or you WILL RIP THE FENDER OUT. Example below of what will happen. Good luck man.
