Understeer with 255mm rear tires?
#31
My point of the reasearch and conclusion is the tire size choice Honda made for the CR is not really 215/255. Its really 215/245 (actual tire dimensions). The RE070's are virtually the same size as most any other 245, and most other 255's are much wider than the RE070 255.
So if choosing tires with dimensions similar to what the CR was equipped with stock is your goal, you really ought to be choosing 215/245.
#32
This is exactly the thinking process my conclusions are aimed at, those 'trusting' Honda engineers research, and going with their 'recommendation'. I am in that camp, not really interested in making lots of mods, I'm running stock wheels, etc.
#33
I completely agree with Bullwings assessment. I ran on 225/255's and compared to the square setup now it definitely understeered a little more. At lower speed turns I could usually use some trail braking to help rotate the car a little. The understeer wasn't bad though. I ran with a '00 FSB and '02/03 RSB on my '06. I had kwv3's with the stock 8k springs all around.
I'm 255 square now no aero still and run with the '00 FSB and original '06 RSB, springs are 11k/9k f/r. Car is very neutral now. Turn in with a square setup is night and day better compared to staggered tires.
#34
Hi Bullwings,
Do you find the CR bar enough for your setup? I'll be going square next year (255/40) on my '07, currently running Ohlins (with their springs) lowered about an inch. Not sure if I should go with a CR or AP1 bar or ante up for something beefier (as suggested on some other threads that I have been reading through).
Thanks
Thanks
So far, the best setup for me has been a smallish wing (GTC-200), CR bar, square 255 wheel/tire, 700F/600R springs. It maintains low speed playfulness to get the quick rotation that I want for tighter low speed turns, and at higher speed the wing balances out to give me the stability and confidence that I need to push harder and keep my foot planted.
Keep in mind that my setup is optimized for track use. If I were to do more auto-x, I'd probably look for a larger/stiffer front bar to improve repeated left-right-left-right transition response and speed.
#35
The CR bar is perfect. It's just enough to balance things out at low speed; however, at speeds greater than 95mph, I do feel a little bit of float, but I think that has more to do with the aero of the car itself and my own skill set as a driver. I tried a 255 square setup with 9"/10" F/R wheel width stagger and didn't care for it. It didn't provide that much extra stability at higher speeds, and it also pushed too much for my liking at lower speeds.
So far, the best setup for me has been a smallish wing (GTC-200), CR bar, square 255 wheel/tire, 700F/600R springs. It maintains low speed playfulness to get the quick rotation that I want for tighter low speed turns, and at higher speed the wing balances out to give me the stability and confidence that I need to push harder and keep my foot planted..
Bullwings (11-25-2016)
#36
Lets say you own a stock 02 ap1 but you are running 17" ap3 wheels. What size tires for 100% street somewhat spirited driving on weekends in summer? How will the choices affect handling at street speeds on good winding roads?
#37
If you upsize just the front, or just the rear, you alter the balance, and will either give you less understeer, or less oversteer, depending on which end you upsize.
Running upsized tires will result in a slightly pinched tire. So its not without some side effects.
Unless you have a specific goal you are trying to achieve, I wouldn't stray from the stock sizes on srock wheels, except as mentioned in previous posts, I wouldn't suggest CR size rear.
#38
This is all a bit confusing to me. Others have suggested that the advantage of significantly increased tire selection and, (they say), slightly improved handling, is a reason to run ap2 wheels and ap2 tires (215 and 245) on an ap1. I did not understand that there was a downside to that modification. I take it you see it differently?
#39
A buddy with an '02 reported nicer overall handling when going to 17" wheels (AP2V1). And a year later nicer overall handling returning to the OEM suspension from the lowered setup on the car when he bought it. Certainly a sample of one (1).
I was curious when I started this thread about potential handling on my '06. I went to the 255mm Bridgestone S-04 rear tires and don't feel any difference from the 245mm RE-11A tires I just took off. I suspect tire selection has the greatest effect and that 10mm makes little difference either way. Another car at the Gettysburg get together just fitted the same tires and I heard no negative comments. I'd expect a 30mm difference in front (245 vs 215) will be more noticeable than 10mm in the rear.
-- Chuck
-- Chuck
#40
If you have a specific goal, like you want to quell an existing oversteer issue, and you don't want to do it right with suspension changes (different spring rates, sway bars, etc), then you can have some impact by upsizing just the rear tires (at the expense of some pinch). Likewise upsizing front only would have the effect of reducing understeer.
Note I am talking about you have a set of wheels you want to use (in your example ap2 wheels on an ap1), and do you run the stock sizes for that wheel vs upsizing one size wider than stock for that wheel.
I understood this was what you were asking. If you were asking what would be the impact of running ap2 wheels vs ap1 wheels (with their respective stock size tires for each wheel), than that is a different question.
