what "widths" do "black" 17 and 18 inch with 5 bolt 114 pattern come in ?
Site Moderator
Enkei lists all their wheel offerings and the sizes on their website. For more limited colors it is best to ask or look at one of the vendors that carries the wheels.
Enkei Wheels | The leader in lightweight aftermarket wheels
Site Moderator
According to enkei deception9 is correct. Also moddiciton. Enkei Lightweight Racing Series - RPF1 UNIVERSAL - Moddiction
For whatever reason in Japan "j" is the width. One of those translation things I think.
Site Moderator
As helpful as the color is what width, diameter and offset are you considering? I am going to guess you will end up with the 17x9 +45 that most people run in which case 255/40/17 is the tire size to run.
my goal is biggest rear tire possible while still running black rpf'1's , il take what ever diameter, off set , doesnt matter , just want to know whats the biggest tire you can fit on a s2000 with black rpf1's....
Former Sponsor
Rolled flat, 255/40/17 on a 17x9 +45 is an easy fit as mentioned above. There is room to go slightly wider in the rear.
18X9.5+45 with 265/35/18 with some pulling and negative camber.
colors can some time be specific to Vendors (ie. victory blue i've only seen at evasive)
J is the Japanese wheel league way of say inches wide i believe. ie 9j is a 9 inch wide wheel. 12.5j is a 12.5 inch wide wheel. Similar to how ET is used for offset ET45 is +45.
