Wheel advice - Front: 17 x 8 +45 (235/45/17) and Rear: 17 x 9 +45 (245/45/17)
Old 10-26-2017, 08:04 PM
nickoces2k's Avatar
Default Wheel advice - Front: 17 x 8 +45 (235/45/17) and Rear: 17 x 9 +45 (245/45/17)
Hi everyone,
I've been doing some research for a while and have been a little confused on offsetting.
I have a completely stock AP1 S2000 and want to upgrade the wheels.
Through my research I'm looking at changing it to:
Will this cause any issues with rubbing? Is that offset too low? (what offset should I get?)
I want to keep it staggered (I've been told this is best for handling).
(I also haven't rolled any guards)
Thanks in advance for your help!!
Old 10-27-2017, 04:22 AM
ZDan's Avatar
Those offsets put the front wheels 10mm outboard vs. stock, and the rears 20mm outboard vs. stock. It can work, but not with those tire sizes... 215/45-17 front and 245/40-17 rear might work. Negative camber highly suggested, fender rolling might be a good idea too but probably not strictly necessary.
Old 11-01-2017, 03:54 PM
Former Sponsor
Jim@tirerack's Avatar
Your tire sizes are off. For the rear you would want the 245/40R17 and front stay with a 225/45R17. The extra width and the lower offset is probably going to cause some rubbing. I would suggest more negative camber and then maybe a fender lip roll.
If I can help let me know.
nickoces2k (11-21-2017)
Old 11-02-2017, 09:36 PM
Site Moderator
Manga_Spawn's Avatar
Yes you’ll need to roll the fenders. Also listen to Jim about the tires.
samg1988
03-08-2011 12:05 PM
ncmx5
01-30-2010 06:36 AM
assalbert
10-22-2007 10:45 PM
owenxguo
11-21-2005 11:27 AM
bdoob
05-01-2005 09:27 PM
Quick Reply: Wheel advice - Front: 17 x 8 +45 (235/45/17) and Rear: 17 x 9 +45 (245/45/17)
