Wheel Fitment Guide
#1071
Hey Manga,
If I went with a Forgestar set up of 17x9 and 17x10, what would be the ideal offset? Forgestar let's you customize it so wanted to get your take. I'm ok with rolling fender and relocating tabs, not so much on the pulling. The car will be used mostly for track duty. Stock suspension so far, but will modify in future.
The 6ULR offset is...
Front: 17x9" +63
•Rear: 17x10" +72
Front: 17x9" +63
•Rear: 17x10" +72
#1072
That is a fine choice if you are looking to avoid fender work. You could even go up to 10" +75 to +77 rear which would give you an extra 3-5mm of clearance.
If you know you are going to roll the fenders anyway and want a more aggressive look then something like +53 front, +60 rear would make more sense.
#1074
Front: 17x9" +63
•Rear: 17x10" +72
Front: 17x9" +63
•Rear: 17x10" +72
#1075
Deception,
Would a 9 inch, +45 in front and a 10 inch, +55 in rear have any rubbing issues? Would a fender roll and tab relocation be enough?
#1077
Site Moderator
#1078
Site Moderator
#1079
Would 17x8.5 +40 245/40/17 fit in the rear without a roll? What sort of drop and how much camber will i need to go without a roll? Will i be able to do 1 finger gap with ~1-2 degrees camber?
