wide body wheels set up
Guys I need some help here. does anyone have oem front fenders and widebody rear quarter?i am having a hard time to find wheels. I want to see your wheel set up, Can you please post your specs as well . Thank you so much
Hello sir, here is my current setup for your reference to what you are asking... oem front fenders and asm rear over fenders. Frons are rolled flat and rears are shaved as much as possible.
i am running:
17 x 9 +40 up front
17 x 9.5 +25 rears
255/40/17 sdrives all around
hope this helps! Oh and wheels are for sale hahaha
i am running:
17 x 9 +40 up front
17 x 9.5 +25 rears
i run oem from fenders rolled flat with a 17x9rpf1+45 with a 255/40/17 with -2.5 camber
rear are cut oem fenders with asm wide over fenders with a custom 17x11.5 + 50 with a 295/35/17 - 2.5 camber. i'm about to go with a 315/35/17 since my tires are about bald.
There no point in going with anything under a 295 size tire when your going for wide rear fenders as the stock fenders can with a 285 to a 295mm size tire.
What are the sizes that should be put under circuit garage style fenders (+45mm front and +80mm in the back)? I want to run 18s but am unsure on how and what to measure once I get them.
not to be rude, but with respect to the OP, i would make a seperate thread for your request. That way also people with the CG setup can chime in and give you more specific examples
Not rude at all! I know it was flirting close to the line of being off topic and jacking OP's thread. I appreciate it and I'll make a separate thread.
