Spoon Sports Engine & Drivetrain Parts - Lots IN STOCK!
Spoon Sports from Go Tuning Unlimited
Go Tuning Unlimited is proud to the Spoon USA Distributor. As a distributor, we have Spoon Sports products IN STOCK with no wait times and special order parts are available with very quick lead times.
We are the Spoon authorized DIRECT distributor.
Spoon Air Cleaner - $115
Spoon Alternator Belt - $155
Spoon Aluminum Radiator - $1290
Spoon Baffle Oil Pan - $595
Spoon Carbon Air Duct - $505
Spoon Engine Mount Ring - $180
Spoon Engine Transmission Mount Set - $515
Spoon Exhaust Manifold - $1610
Spoon Head Gasket - $175
Spoon Magnetic Drain Bolt Set - $45
Spoon N1 Muffler Kit - $1005
Spoon Oil Filler Cap - $85
Spoon Radiator Cap - $35
Spoon Radiator Hose Set - $285
Spoon Radiator Stay - $25
Spoon Reservoir Tank Cover - $15
Spoon Spark Plug Cover Carbon Kevlar - $155
Spoon Thermo Fan Switch - $60
Spoon Thermostat - $90
Spoon Valve Cover Yellow - $490
Spoon Venturi Big Throttle Body - $620
Spoon Venturi Big Throttle Body AP2 - $720
Spoon Capacity-Up Diff Case - $965
Spoon Clutch Cover - $490
Spoon Clutch Disc Metal - $450
Spoon Clutch Disc Non-Asbestos - $285
Spoon Clutch Line - $115
Spoon Differential Mount Set - $475
Spoon Driveshaft Spacer Kit - $245
Spoon Final Gear Set 4.44 - $1265
Spoon Flywheel - $540
Spoon LSD - $1265
Spoon Release Bearing - $180
Spoon LSD - $1265
Yes, the Spoon short antennas were made for the Honda Fit and worked on the S2000. But the Spoon antenna was different than the stock Honda Fit antenna.
