Bouncing idle and strange lag (video to demonstrate)
Old Mar 18, 2013 | 10:16 AM
ajk's Avatar
ajk
Default Bouncing idle and strange lag (video to demonstrate)
On a couple of mornings now I have a weird problem when I start up the S. The RPMs shoot up to around 2500 and then drop to 2000 and starting bouncing this way. The engine feels like it's running rough and struggling.
On the mornings that it starts fine, the same thing will happen when I give it a little throttle: http://www.youtube.com/watch?v=HxwQAmMOsqI
As the engine warms up the issue starts to go away, but there's usually noticeable lag whenI hit around 2500-2800 RPM.
Ideas?
Thanks!
Edit: car is all stock
Old Mar 18, 2013 | 10:29 AM
ajk's Avatar
ajk
After some more research, stuck or dirty IAC?
Old Mar 18, 2013 | 10:58 AM
Reckon's Avatar
Not sure I got anything out of that vid. Did the bouncing occur from you hitting the gas just once or was it just a constant pressure on the gas pedal?
Old Mar 18, 2013 | 12:39 PM
ajk's Avatar
ajk
Constant and steady pressure. Kept bouncing until I let off. And some mornings it will do that while idling without me touching the gas.
Old Mar 18, 2013 | 02:27 PM
ajk's Avatar
ajk
Caught it doing it at idle without me touching the gas!
Video
I'm not sure if it's coincidence, but every time it has done exactly this, the of the car was elevated on jack stands for a few hours ...
Old Mar 18, 2013 | 02:42 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Stuck IAC rotary valve, guaranteed 100%.
Old Mar 18, 2013 | 02:59 PM
ajk's Avatar
ajk
Thanks!
Possibly stupid question, but: It's a 2007. I'm looking at my Helms manual and it appears there's no IAC valve on '06 and '07s?! I see the throttle body has seen some changes...
Left shows '00 to '05, right shows '06 and 07: Bouncing idle and strange lag (video to demonstrate)-nx8gzea.jpg
Old Mar 18, 2013 | 04:19 PM
RichSouth's Avatar
Do you have an engine management light on? I have the same issue exactly and people are suggesting it's the 02 sensor, although I have and engine management light on...
Old Mar 18, 2013 | 05:33 PM
ajk's Avatar
ajk
Nope. CEL is off. I suppose I'll stop by the dealer tomorrow and get their "2 cents"
Old Mar 18, 2013 | 05:43 PM
Billman250's Avatar
Top Answer: 1
Year would have helped yes, so no iac is not the problem it doesnt have one.
