Sponsored by:
Sponsored by:
Wheel fitment help
Old Apr 5, 2013 | 07:52 AM
baZurk's Avatar
Default Wheel fitment help
Will a 17x8.5 +35 square setup fit? After a search, I think the rears will fit if I roll my fenders. I am unsure about the fronts. I think it may be too aggressive. Any insight is greatly appreciated.
Old Apr 5, 2013 | 08:33 AM
Fierc3's Avatar
I ran 17x8.5 +50 255 40 17 star specs on the rear. Stock suspension ap1. I would rub / hit on hard bumps.. So you will def. need to do some fender work on the rear.
Old Apr 5, 2013 | 08:37 AM
baZurk's Avatar
I read that with a 245 tire and rolled fenders the +35 would fit in the rear.
Old Apr 5, 2013 | 09:31 AM
Mr. Lin's Avatar
and a good amount of camber. let's not forget.
Old Apr 5, 2013 | 09:49 AM
baZurk's Avatar
From what I read -2.0 to -3.0 camber should work in the back. Proabably closer to 3.0
Old Apr 5, 2013 | 10:14 AM
s2000Junky's Avatar
What kind of susp drop are you going to be running?
The rear will fit no problem with rolling your fenders and bumper tab relocated. 245/40 will be your best fitment at -2 camber. If you went -3 camber in the back its very possible you could squeeze a 255, but hard to gauge with how different tire sizing/profile can be across the manufactures. Your riding that line.
The front with a 235/40 would be a good mate for the back, almost square set up but a good fit for the rim width. 215/45 would be doable but really stretched. If you roll the fronts and pull the fenders 10mm with -2.5 camber you should not have a problem with the 235/40 fitment. With a 215/45 you can go a little less extreme with either the fender pull or camber, your choice.
Old Apr 5, 2013 | 10:17 AM
baZurk's Avatar
The rear will fit no problem with rolling your fenders and bumper tab relocated. 245/40 will be your best fitment at -2.5 camber
Ok so I am guessing a 245 square setup is out of the question? I will probably be dropped 1.5 inches.
Old Apr 5, 2013 | 10:21 AM
s2000Junky's Avatar
I would be impressed, I will put it that way. If you could get -4 camber out of the front with an aggressive fender pull, you would be in the ballpark. a 235/40 will be more reasonable/streetable.
Old Apr 5, 2013 | 10:25 AM
baZurk's Avatar
Ok makes sense. I would've prefered more firendly offsets but the rims I'm looking at are this size. For just this instance, I'm leaning a little more towards form then function. lol
I'll keep the set up in mind. Thanks for all the help.
Here are the rims I am thinking of getting
Work RSZ-R's
Old Apr 5, 2013 | 10:28 AM
s2000Junky's Avatar
Yep nice wheels
Good luck!
